you want to make a hole about 25" dia. in a piece of lead 4" thick? whats the purpose of this excercise? if you could lift it, maybe a vertical turret lathe would be easiest, but you still need to lift the slug out of the center which is still damn heavy.
CNC the bugger. Circular interpolate, leave stock, retract the tool, pull out the center plug, do a finish pass.
Oh, no CNC?
OK, I had to cut out a 12 inch hole in aluminum plate 20 x 16 once. Hung the head out a bit, got my biggest boring head out. Created a HSS tool on the end of a HSS bit type boring bar and hung it right out there from the side hole - the head a 3" dia. head, bar out about 4 inches like a big old fly cutter - but ground to cut downwards. Reliefs and such on the tool interesting, but it worked. Cut out the hole at 11.625 first, almost through. Had the plate mounted on a piece of plywood ahimed and such - plywood so I would not cut the table, and to fully support the part on the bottom instead of blocks and such.
Cut nearly through until the part started to break away in the hole "plug" area. Retracted the tool, took a scribe and finished out the bottom scoring through, pulled the plug.
Finished the hole like a bore hole. Did three of these for a full size model rocket flying off in New mexico (one of those 12 ft. things that goes 6000 feet up).
watch your heat when working with lead if sh gets hot it starts to stick to the tool bit and its softness makes things a mess fast. (yes I learned this the hard way)
