A simple center finding wiggler for lathe
  • A simple center finding wiggler for lathe
    I found this variation of a wiggler on another forum, instead of using a drilled brass ball for the pivot, I used a small piece of rubber instead. Much simpler and should work just as well. Hardest part was finding the rubber.
    Why not use RTV?
      I guess you could.
