Ok should be quite simple... but so far it's a pain. I use a rivet gun quite a bit. The one I've used for the last 20yr finely gave out handle snapped in two. So I go on a hunt to find a replacement should've been simple. Picked up a new Arrow with a pivoting head. Back to shop... wont work the dang head was flexing would not apply enough force the snap the steel mandrel of a 3/16" rivet. Take it back.. over to K-ear's to get a Kraftsman " Heavy Duty ". Well I did 6 rivets and I hear a odd snap on the 7th and it jams. Pull the tip off and one of the jaws broke.. so back it'll go. Now I'm wondering if I've got into a lot of funky rivets. I mean the old tool (which I'll fix back up... I plan on milling a tongue and cross pinning a replacement handle) ok sure fatigue can explain that... but first one don't work and second break in less then 5 minutes... come on. Any ideas of a good manual rivet gun... just in case my repair goes south.
Tim
Tim
