Cognac
Seasonal Affective Disorder
It must be something common to those of us north of the 49th parallel. I haven't sleped much in the last week or so. With any luck I will get to try Wayne02's cure tonightTo invent, you need a good imagination - and a pile of junk. Thomas A. Edison
<font face="Verdana, Arial" size="2">Originally posted by Wayne02:
I've found that wild passionate sex is very exhausting, especially at my age. Usually don't have any trouble getting to sleep after that, regardless of what time it is.</font>
Try an OTT light, it is sun spectrum in colour and generally not too expensive unlike those "medical grade" lights.
http://www.ottlite.com/
Jerry
I get this now and then. My general solution is to try and spend as much weekend time outside summer AND winter regardless of weather, and make a special point during the fall and winter sunny days. Sounds too easy, but this was a suggestion by a researcher at Dartmouth Hitchcock. Been five years since that suggestion, and it seems to have worked.
Geeze, I find that in the winter, I have to resort to the dark times doing "shop therapy".
CCBW, MAH
I think I have improved my shop lighting by installing some GE Full Spectrum Flourescent tubes in many of the fixtures. These are quite expensive - at about $6 each - compared to normal 4 foot tubes -at about $1 each, but I bought 10 of them when Home Depot changed brands from GE to Philips, and dropped the price to about $3 each. I use one full spec tube per 2 tube fixture. It is pretty well lit when all fixtures on.
