Converting round to hexagon or square
  • Converting round to hexagon or square
    Can anyone help with a formula that will give me the OD. reqd .to be able to mill an across the flats hexagon or square of any given size.
    ie..... What will be the largest hexagon or square from any given size of round bar.
    I've looked on Marv Klotzs site but cannot see a formula for this.
    Allan
    Allan,
    For a square, multiply the bar's diameter by 0.7071 (ie. square root of 2)
    For a hexagon, multiply the bar's diameter by 0.8660
    hth,
    Ian
    All of the gear, no idea...
      Allan,
      To work it out for any regular even faced polygon, take the angle between a flat and a radius from the end of the flat, and find it's sine.
      ie. for a square, the angle between a radius and the end of a flat is 45 degrees; sin 45deg = 0.7071
      Ian
        Thanks Ian,that was just what I was looking for.
        Allan
          Allen,
          There's a chart in the Machinery's Handbook in case you don't want to do the math...Goes up to 4 1/2". It's on page 169 of the 18th edition. Squares and hexes only, though.
          Andy Pullen
          Clausing 10x24, Sheldon 12" shaper, Clausing 8520 mill, Diacro 24" shear, Reed Prentice 14" x 34"
            Ian, I thought the proper function was cosine.
            D = size across desired flats divided by the cosine of the angle 360/n where n = number of sides.
            Working the other direction: size across flats = diameter times the cosine of the angle 360/n
              I use a program called Machinists Friend. It works great.
              Jerry
                Allan:
                There's no explicit formula for this on my page. You could easily work it out
                with my CSEG (Circular SEGment) program, although that's probably more work
                than simply drawing it and doing a bit of simple trig.
                The formula you want is:
                D = daf/cos(360/N)
                where:
                D = required (cylindrical) stock diameter
                daf = distance across flats
                N = (even) number of polygon faces
                You may want to examine the TENON program, which will calculate the depth of
                cut you need to form each polygon face.
                Regards, Marv
                http://www.geocities.com/mklotz.geo
                Regards, Marv
                  This might help...
                  Arbo & Thor (The Junkyard Dog)
                    Thanks to everyone who replied,I can now make the appropriate hexagons.
                    Not having done any trig. for more than 45 yrs I have forgotten how to work things like that out.
                    Allan
                      Allan, it`s time to dust off the old log tables
                      Seasons greetings, Ken
                      Ken.
