Heads up,twistlok plugs cheap
  • Heads up,twistlok plugs cheap
    Went down to Lowes today and bought some new shoplighting.Also noticed they had three~ twistlok cord plugs and receptacles.
    I got a 14-20 plug for $11.06 and a 14-20 receptacle for $13.07,plus they had 30 amp for a little more,even American made.This beats the normal $20+ out of the catalogs.
    Also picked up a set of Klien wire strippers,USA,and probibly the best set I have ever used.
    [This message has been edited by wierdscience (edited 11-28-2004).]
    Lowes: I picked up another 500' of 14ga. thhn stranded wire for $20.. Not sure why it is cheap at the moment. I gave $35 back in the summer for the same type wire.
    Good for 15 amps by the way.. Up to 600 volt insulation..
    I used more than 500' the last time I tore into my milling machine. And that was not a major refit, just some additional controls.
    David
    [This message has been edited by ibewgypsie (edited 11-29-2004).]
      Good deal,got to check that out,I go through 500' or better of 14,18ga every so often myself.
      They also got a heavy Hitachi 4-1/2 side grinder for $89.00,good thing its Christmas
