Boring Head in a Lathe?
  • Boring Head in a Lathe?
    I?ve enjoyed reading the comments and discussion in this forum and others on the many uses of a boring head. I?m puzzled, however, by some notes (and descriptions in catalogues) that say a boring head can be used in a lathe tailstock. Is this possible or advisable? If so, how would you use it?
    Thanks to all
    screw machines use boring heads all the time some even have sping loaded slides to move the tool out after going deep into a bore to chamfer the inside of the part before it is parted off.
    one time on a big semi truck bell housing that hade a worn throwout fork pivot hole.
    I put the holes bettween centers, jacked and clamped the bell housing to the cross slide.
    put the borring head in the chuck and bored the hole to take a stock bronze bushing. (a lathe makes a nice horz. boring mill)
      I've done it and it works just fine, not sure that its the right way to do it though. Any particular reason why you can't use a boring bar in the tool holder?
        You can use it for boring or as an adjustable tailstock for steep taper turning - less hassles that reseting your tailstock to precise center if you do lots of taper turning - or weird stuff.
          Seems like it would be a useful application on a turret lathe. Not necessary on a normal tool holder based boring operation.
          John
          Pursue Excellence and the rest will follow.
