After grinding the magnetic chuck on my Shipman grinder to true it.....I then created a test peice of bright drawn, roughley 6 inches long by 1.5 inches wide and 3 quarters deep.
I ground it both sides then took it to the inspection room of my friend Alwyn who owns a pricision engineering business.
He put it thru the works using the most sensitive measureing devices on his huge granit surface plate/table.
only two microns deviation.
so I'm over the moon that my so called junker turned out to be a good buy
All the best....mark
btw one micron is 0.001 millimeter
or 0.00003937 inch
[This message has been edited by aboard_epsilon (edited 12-02-2004).]
or 0.00003937 inch
