servo II mill motor coupling?
  • servo II mill motor coupling?
    Is anyone familiar with these motors and can you tell me where to get a replacement coupling preferably not OEM because of design and expense for what you get, or does anyone have any ideas for making one yourself?
    Shaft to shaft size, distance between them?
    That is all you need, there are 3/8"x 1/4 spring couplings I saw in the recent All electronics catalogue.
    David
      Well these are a bit different in that one enters the other so its not as easy as it should be, I will get the sizes a see what I can find. The oem one costs almost $200.00 I think that might be just a bit high.
