metric left hand tap
  • metric left hand tap
    Does anyone know of a source for a M8x1.25 left handed tap?
    If I have to make one, should it have 2,3 or 4 flutes?
    This is to tap only 3 holes but they are 1.5" deep.
    They are availiable from McMaster-Carr or MSC. They will not tap the 1 1/2" you are looking for though. Perhaps you could clear drii the hole on one end. [http://www.mcmaster.com
    http://www.mscdirect.com
    [This message has been edited by ERBenoit (edited 12-06-2004).]
      MSC should be able to supply you with one. I recently purchased a metric left handed tap from them. Loaned it to a friend of mine. One little job to clean up some threads. It was returned. Cheaper to buy than to try and make.
      SK
        Once had a job where the threaded hole was deeper than the tap flutes; the machinist doing the job, ground the shank behind the flutes to get the extra depth.
        Harry
          I didn't think of it right away, but beckley 23's suggestion, I have quite a few taps ground as such just for that purpose. I do not use then often, thus not thought about until I need one.
            You can buy taps with the shank relieved. Don,t know where, we had some at work, if you want longer taps look for pully taps.
            Good luck.
            Russ H
              Thanks guys...again! I love this site, so much info.
              BTW, since this is for steady rest fingers, I may not have to thread the whole depth of the hole, just drill deep enough to provide clearance for the "bolt".
              [This message has been edited by joahmon (edited 12-07-2004).]
              That was a dumb thought. I need to come in from the other side with a larger drill!!
              [This message has been edited by joahmon (edited 12-08-2004).]
