rod for Tig welding Titanium?
  • rod for Tig welding Titanium?
    Any hints on which rod to use to TIG Ti? Alloy is either grade 2 or 5. Also, which tungsten to use?As for gas, Argon?
    thanks,
    -Armen
    Re gas, I've been using straight argon on G11 Ti. Just checked the wire but can't find any numbers. I've had it so long I can't even remember where I got it. I've got a feeling it's just CP Ti wire. Runs a beautiful bead but you need high gas flow. Slightest sign of blue and the part is worthless. You may need back purge and trailer shield if you're doing anything more than small parts.
    Rgds, Lin
      Oh, tungsten is just the usual 1% thorium I use for everything else
        Armen
        If the weld is a critical application it may require a specific alloy for the seam for chemical or strength considerations. If it is a mundane application - don't worry about it.
          <font face="Verdana, Arial" size="2">Originally posted by Thrud:
          </font>
          Mundane? Yep, like a Ti fence post
          JRouche
            Astrolite in California sells Ti welding wire. I just bought 2.5 pounds (@ $85.00/lb) of the stuff...only problem is they have a $200.00 minimum. Wire arrives in argon shielded protective bags, cool. http://www.astrolite.com/pages/prod.htm
            I use a laser welded with argon gas, so I do not know about what tungsten to use.
            Bill
              <font face="Verdana, Arial" size="2">Originally posted by JRouche:
              JRouche
              </font>
              Are you nuts - or just have too much money?
              What a waste of Ti...
