how to add links?
  • how to add links?
    Can anyone tell me how to put a link in a reply?
    If the link is short then just copy it from the address bar and paste it in your message.
    If it is long then "tag" it.
    To tag it do this:
    type
    Then type a descriptor such as Click Here.
    Then end the tag with
    Example:
    [*URL=http://really.long.url.that.wont.fit.on.the.screen]Picture here[/URL]
    Grr. Fighting with the BBS software. I had to put an extra "*" character in the URL tag to stop it from working so you can see the example.
    [This message has been edited by Evan (edited 12-11-2004).]
      thanks Evan, have a good day.
        And for pictures read Evans thread in Networking on posting pictures from Photobucket
          Is that how you add a signature to your profile?
          Gene
            Edit your profile. There is a place to enter a signature. Consider it carefully as it will be on every post you make.
              Evan, I have put a line in the signature box but it doesn't come up. Do you need to put that url in front and behind the line?
              Gene
                Evan, I have put a line in the signature box but it doesn't come up. Do you need to put that url thing in front of, and behind the line?
                Gene
                  Maybe I've got it. I'm trying again.
                  [This message has been edited by topct (edited 12-12-2004).]
                  Gene
                    Consider this a test thread. I'm not sure if you can put a URL in a sig. Let's try.
                      test
                        test again
                          Darn, I was trying to put an image in my sig but it doesn't seem to work
                            test, I just put my name in the signature box and it doesn't show, is the box broken?
                            Gene
                              I guess you need to check the 'Show Signature' box. Duh
                              Gene
                              Gene
