Cincinnati Toolmaster Drawbar Removal?
  • Cincinnati Toolmaster Drawbar Removal?
    I'm restoring a Cincinnati Toolmaster vertical mill.
    Can someone who has "been there" please describe how to remove the drawbar? I have the manual but it is not obvious what I need to do.
    At first I thought it must come out through the top (remove gearbox/motor and so on), but perhaps it is easier to drop the quill/spindle down and get at it that way?
    Thank you,
    Jeff Rininger
    good morning.
    what kind of toolmaster do you have?
    i have a 1-b model that uses craley collets and doesn't have a drawbar.
    i am curious......
    peace.
    bill
    ........i dremel. therefore i am..........................
      <font face="Verdana, Arial" size="2">Originally posted by billr:
      good morning.
      i am curious......
      peace.
      bill
      </font>
      Hello Bill ! I have a Toolmaster 2B - has a 40 taper spindle and a variable-speed head.
      Best Regards,
      Jeff Rininger
        Check at the top of the drawbar if there is a cap. I have a converted contour master. The threads are left hand at the top of the splines / quill.
        Hope this helps,
        Frank
