Penetrating oil
  • Penetrating oil
    I've read this thread with interest because I have handled this kind of problem many times. It is aluminum oxide having migrated molecularly into the threads to create an unbelievable grip. It is also so tight that it is nearly impossible to soak any kind of penetrant or lube into it because it isn't very porous. It would be interesting to see some cross-section views of all of these methods to see how far the penetrating lubes were able to get.
    I've almost always had to drill out and retap. Sometimes when the drill has exposed some of the threads those other solutions can get in to do some chemical work.
    And on the idea to use air-pressure on a stuck piston out of a cylinder head, I just want to chime in against it as too dangerous. The same effect is better done hydraulically with better results and less explosion and less flying pieces of metal bouncing around the shop.
    Penetrating oil
    I'm trying to free a stuck cylinder on a
    motorcycle. Its aluminum cylinder held on
    with four studs.
    One of the (4) studs is seized to the
    aluminum. I tried Kroil, is there anything
    better than that crap?
      Have you tried the thermal trick? Try applying heat with a propane torch to the aluminum while the end of the stud is in ice. Mebbe the temp differential will be enough to unstick it.
      HTRN
      EGO partum , proinde EGO sum
        Heat and dry ice saved the day for me once.
          The problem is, the studs are recessed
          below the cylinder deck.
            I made a puller using a 1/2" steel plate and
            a port a power. I heated the f--k out of it
            with an oxy-aceteline rig, still no dice!
            h2madness.com/machineshop.html#five
              One of the old trick to remove aluminum heads on the old flathead engines that had corroded was to pour coke on the studs and let them sit for a while. The coke would eat the corrosion that had formed in the hole and on the stud. With a little tapping and some heat they would release and the head could be removed.
              Kroil is the best penetrating oil out there.
              Hope this helps,
              Joe
                Another old trick is to heat the stud, touch it with beeswax and unscrew. Good trick, won't always work-but I know of NO trick that always frees dissimilar metals.
                Kroil- High on my list of liquid wrenches.
                  maddog --
                  I hear rumors that ammonium hydroxide solution (such as Bo-Peep or Parsons brand "ammonia" sold at the grocery stores for cleaning) is the slick trick for freeing corroded aluminum. It's supposed to break down the corrosion byproducts.
                  John
                    I'm fond of kerosene as a rust penetrant. I'm fond of kerosene for a lot of uses, come to think of it. If they made women's perfume from it, I'd spend more time with my wife, and less in the shop. Seriously, I wouldn't let her out of the bedroom except to eat and bathe.
                    You could always pour Castrol Super Clean on the head. That'll dissolve the corrosion, and the HEAD. Poured some in a Coke can one time, just to see. 15 minutes later, the can was Swiss cheese.
                    I'll have to try ammonia.
                      Try Gibbs if you can find it, I think they have a website. A lot of the antique engine guys think it is best for stuck engines. J.R.
                        maddog
                        whose welding is this? http://h2madness.com/images/man_h1.jpg
                        It looks just like the welds I do. On a good day.
                        Justin
                          Those are some of my beginner welds from 2
                          years ago, (they were pressure tested)
                          I'm much better better now days, the more
                          you do it the better you get.
                            Worst case scenario is you strip the threads out of the aluminum, and there isn't enough meat left to drill out and put in an insert. Before doing damage, and after all else has failed, I would drill the head off( if a bolt), or cut the stud short with a hacksaw, then drill out the bulk of the metal. Then drop in some solution that will eat the steel but not the aluminum. Hopefully the threaded hole has a bottom. It would be good to tape off openings so saw debris doesn't get into things. Use a magnet to help with cleanup, wash up and neutralize whatever the solution is that eats the steel.
                              Justin
                              Thats the sort of weld you get if you weld galvanised steel without grinding the galvanising off.
                              so if he didnt know about galvanising
                              ...thats the result you get .
                              even an expert welder could not do any better on galvanised work without grinding.
                              easy mistake to make when your beginning.
                              all the best....mark
                              [This message has been edited by Mark Jones (edited 10-01-2004).]
