Anybody have info manual parts diagram etc on an old precision Hardinge lathe (green- I think original paint) with collet closer/collet trays steel legs and butcher block table mount(I believe it came with base). It could be WW2 era or later from the old Bulova factory that my colleague worked at. Lots of contacters under table. Large lever at headstock. About 30"? between centers. Nice precision lathe that we are trying to get started again after difficult to trace electrical problem.
