Making an air sled
  • Making an air sled
    Have any of you guys made an air sled before? I want to make one for my tablesaw and I could use a bit of advice on making one. You can see a comercial version @ www.airsled.com
    How do you calculate airflow? The footprint of the base of the tablesaw is about 24" X 60" and it weighs about 600 pounds. My compressor is rated @ 12 SCFM @ 90 psi. Also, what would be the best material to make the sled out of? The sled will have to move around on the concrete floor of my garage.
    Thanks
    Andrew
    I thought this was an air sled.....
    -3Ph
      You'll need absolutely smooth/level surfaces to operate on. I looked up this matter about 2 years ago. Do a Google search for "air caster".
