I have to glue (or something) some uhmw into 1/2" wide by 1/8" deep slots in aluminum. I was going to run screws in from the back but the screws will stick out too far into the plastic. I was wondering if the P-tex sticks used for ski base repairs would be compatible with uhmw? Drill a hole in the back of the alu and melt P-tex into the holes, gluing the inserts in. Or would some type of epoxy work for this? Thanks!
Russ
Russ
