So to amend my review and removing errors:
Taking a break from more onerous tasks, I got out a Christmas present for the first time to see if would perform better than my skepticism predicted. Yup. My rotten grandlings got tired of listening to me bellyache about not being able to see well enough to sharpen drills free hand so they got me a Drill Doctor 750 for Christmas.
First impressions. Neat compact kit in a blow molded case with all accessories, two chuck/cam arrangements, a little wrench for changing the grinding wheel, and finally a video tape in case my famous instant mastery of all things mechanical suddenly lapsed. Everything made sense and went together in a logical sequence. The instructions were crystal clear with plenty of illustrations to guide each step. There are numbers on the case of the Drill Doctor to follow so you don't mix up any steps.
This gadget performs as advertised. It'sa claimed capacit is twist drills from 3/32" to 7/3". Follow the steps and you can sharpen a drill as well as I could in my prime (which is pretty damn good if I do say so). You have a choice of conventional grind or split point and it will sharpen masonry bits should you ever need to. The 750's two "chucks" are cheap looking affairs having hardened sheet metal jaws. The rest of the machine is stout plastic and I don't mean this in a joking way. Many plastics are endure the rigors of the open shop better than metal if the application is selected with the material's characteristics in mind.
I have plenty of dull drills so I did not lack for demonstration material. The Drill Doctor sharpened a 1/2" drill spot-on and split the point precisely. I then used it to to drill a 0.503 hole in mild steel and it did so with two full width chips spiraling out of the flutes; a perfect textbook grind.
The Drill Doctor sharpened my test drills from 3/4" down to 3/32" and ground good concentric point on them both split point configs and regular grinds.
I sharpened my 3/4" and under drills with the larger chuck without trouble and they drilled on-sized holes.
The manual gives you clear instruction on maintenance and what signs to look for to determine wheel wear and how to flip the wheel over when the abrasive poops out. The manual goes on to say the little diamond wheel it comes with is good for maybe 200 drills. Only 200? In a busy five man shop 200 drills accumulate in the "sharpen me" coffee can in a week or two. Given that the replacement wheels cost $26, that alone brings into question whether the Drill Doctor is adequate for any but the small home shop. Well, that's how it's advertised and that's where I'd place it.
Drill sharpening can be a bafflement for people without good "eyeball" genes. In the Drill Doctor those running a home shop have a gadget available for a modest price which will keep the dull drill backlog to a minimum.
Small commercial shop owners better get the Drill Doctor's larger cousins because replaceing the litle diamond wheels will bust the economics justifying its purchase.
Adding from a later post:
Ensure the Drill Doctor chuck/cam units are correctly assembled so the jaws engage the slots in the thrust collar as well as the slots in the barrel. Mine were not and when I disassembled it for inspection and diagnosis I incorectly reassembled it in the same way it came from the factory. Without correct assembly it will not sharpen smaller drills so the point is correctly centered.
The spring jaws inside the alignment port sometimes hang up. Be sure to wiggle the drill while it's a bit loose in the chuck so the spring jaws in the alignment port index the drill in time with the cam in the chuck. Only then do you snug up the chuck.
Closely examine the clearance angle on smaller drills. I discovered on my unit the smaller the drills got the closer the as-ground clearance got to zero. While they cut they were slow to feed. I set the alignment adjustment lever to "+" to gain a bit more clearance and the drills cut better. This lever needs some intermediate positions.
There is a condition called "margin wear" (the skiny land where you actually measure the size) where the first 1/4" or so of the margin is worn under the drill's niminal size. The drill has to be cropped back to where the margin is unworn for safisfactory results.
Follow these steps not mentioned in the manual and you'll sharpen drills from 3/4" down to the 3/32" minimum so the points are accurately centered.
Sorry for my screw-up. I fully endorse the Drill Doctor as a drill sharpening asset for the home shop.
[This message has been edited by Forrest Addy (edited 01-07-2005).]
