small boring bar? HSS??
  • #16
    I'll have to take a picture this evening of the special trick boring bar that I got with my unimat. It will fit in a 1/4" or possibly smaller hole. I also have made special purpose boring tools using standard 1/4" square HSS tool stock and a whole bunch of grinding.
    • #17
      Here's a 1/4" boring bar made by Kennametal
      with indexable carbide inserts. It has come in handy many times for me,I dont know if they still make it tho.
      Here's some photos of it.
      http://img.photobucket.com/albums/v6...bideinsert.jpg
      http://img.photobucket.com/albums/v6...lBoringBar.jpg
      Regards
      Ivy_McNeil
      • #18
        Router bits work too.
        • #19
          I meant to photo this the other day. Here is the trick little boring bar that came with the Unimat when I bought it. It uses a special cross section HSS bit that clamps in a split collet which screws into the end of the bar to hold it. The other end of the bar holds at 45 degrees. The tap beside is 5/16". I have about 8" of the special section HSS tool steel left.
