Friend..
A VFD is a phase generator that can vary the speed. I have one on my machine. My machine just has a 2hp motor thou. I have a single phase input, 3 phase output inverter. It has a limited number of starts per minute thou. If you plan to do manual tapping (fwd-reversing) a lot you have to go bigger.
A rotary phase convertor is a unit that uses inductors and capacitors and possibly a pony (idle motor) that generates a simulated phase out of the 180 degree single phase power.
I have a 10hp 3ph motor started with a belt connected 120volt 1/2hp single phase motor, then I slam in the contactor. It will run all the 3phase machines in my shop. Smoothe. No cost other than the motor and the contactors.
David
David
