I'm (obviously) a newbie. What sort of problems should I expect trying to machine welded parts, or shapes cut from plate via oxyacetylene cutting? Won't the heat from the cutting/welding harden the metal (mild steel)? Will I need carbide tooling?
All input appreciated.
Jeff Greenblatt
Jeff Greenblatt
