Moved from another post:Speaking of ring gears John, are you making them from scratch or weld/repair? I need one for a Kubota and can't seem to get one without buying a whole freakin' lower end--about $1200.
I figure I can weld new "teeth" and grind them back into profile. The problem is; I'm afraid of weld srinking the ring and not being able to get it pressed back on the flywheel.
Any suggestions?
Any suggestions?
