I am working on a project that I would like to dress up a bit. I have never done jeweling on aluminum (also known incorrectly as engine turning). I want to apply this finish to aluminum and have tried several different approaches. I tried a hardwood dowel with fine abrasive. I tried a pencil eraser. I tried a turned teflon dowel with fine abrasive embedded in it. None of these approaches worked satisfactorily.
The aluminum is soft and picks up the slightest extra piece of grit and leaves a nasty mark in the pattern.
Ideas?
Ideas?
