Hey guys! I took a Holley double pumper in trade the other day. Not much for trade, the front shaft was really loose on one side and it was very hard to tune due to all the extra air it sucks. I was looking to just use it for parts but now I'm thinking why not bush the hole and make it useful again. It would mount up nice on it's side on an angle plate but I'm wondering how is the best way to center this thing. I was thinking of shimming the shaft (after removing the plates etc) so it worked free then chucking it up in a drill chuck...let it hang and move the tables/angle plate around til it matched the base of the carb. But then I realized that this is just another of my hillbilly setups. The hole on one side is the only one that is really worn out (he had the carb for many years and used REALLY heavy return springs). I can see how to center it with a coaxial indicator but can't see how to make sure the setup is true all the way through. Hope you follow what I'm trying to say. How would you guys set this up! Thanks!
Russ
Russ
