Ratios
  • Ratios
    Is there a ratio between the diameter of the crankpin and the thickness of the parallel rods and main crank rods of a side rod locomotive? My free lance job has 5/8" diameter crankpins. What should the thickness of the rods be?
    7 1/2" gauge, I assume?
    I don't know offhand, and I doubt that there is a single fixed ratio, but one obvious thing to do is go through back issues of Model Engineer, Modeltec, Live Steam, or whatever, and see what was done on other engines.
      Al
      Make them like the rods on a real loco similar to your freelance model.
      What're you making?
      mite
