What's this for?
  • What's this for?
    Does anyone know what this is for?
    -3Ph
    Is this a test?
      It's a left hand version of one of these.
      John S.
        LOL... You guys.
        Looks like a motor with an adjustable belt tension mount. (Like those found on drill presses.) The front motor mount and the shaft is missing though.
          It is a genuine dohickey doodad gizmo thingmajig whatchamacallit.
            Well, whatever they are the two of them make a set and have to be worth a whole lot more
            Ken
            Ken.
              Gee, havn't seen one of those for years, they really work great!!
                If you had the other two, you'd have a full set of three!
                Doc.
                  Mark 2 antigrav generator, not worth a whole lot since the mark 3 came out last month...
                    It's just a little hard disk motor. When I say little, I mean little:
                    1979 IBM RLL Hard disk
                    Size: 12" x 12" x 20" 50 pounds.
                    Capacity: 64.5 MB.
                    And here is today....
                    2004 Hitachi SATA Hard disk
                    Size: 3.5" x 5" x 1" 30oz
                    Capacity: 400 GB
                    One of these drives is over 100 times faster, and is equivalent to a stack of the IBM drives 79 feet high by 79 feet wide:
                    -3Ph
                      Ha!I got one of those old IBM units at work,sitting out in the rain!Want it for use with the other as bookends?
                        <font face="Verdana, Arial" size="2">Originally posted by wierdscience:
                        Ha!I got one of those old IBM units at work,sitting out in the rain!Want it for use with the other as bookends? </font>
                        This one is actually the first "hard disk" with thin-film magnetic heads.
                        Do you know what the model number is for the one you have?
                        -3Ph
                        [This message has been edited by 3 Phase Lightbulb (edited 01-17-2005).]
                          3ph,that motor must have SOME use.i assume it's fairly high speed,so how about a mini grinder?
                          alternatively,an anchor for a model boat?
                          Hans
                          Hans
                            Hah. Want mini motors? I have a bunch of these but have never figured out a use for them yet. That is a .22 long rifle round for size.
                            [This message has been edited by Evan (edited 01-18-2005).]
                              Geeminy....I remember when adapting a 5mb HD to your SWTPC 6809 system was pretty high tech, and who would ever use up THAT MUCH storage?
                              The SWTPC had 64K memory space, with hardware memory paging of several of those spaces on the processor board. I still have a SWTPC 6800 in storage, and a 6809 board that would fit it.......
