Hi all, I recently received my 12" Craftsman lathe and have been cleaning it and purchasing/making some of the missing items.
I don't have a center for the taistock at the moment but when I put a center in the headstock and a center-like tool in the tailstock drill chuck, it appears to be slightly mis-aligned.
My question is....is it a tough thing to correct if this IS in fact the case?....I will wait to actually check it with a center before true-ing it up with the drill chuck 'cause that seems to be more desirable.
I've never messed around with the tailstock on my other lathe, but I've seen it mentioned in books and magazines that folk'll slide it over for one reason or another (turning tapers I believe).
The lathe seems to be circa late '30's, early '40's if that makes any difference.
Thanks for any input,
John
John
