I ended up with a flamecutter, the vertical torch. I had it on my rig but it sounded like a 747, the tip was a tad large to do what I wanted to do. It blowed a crack 1/2" wide. Popped and went out trying to set a lower flame.
The carrier, a variable speed trolley looking deal, it has geared wheels (serrated) underneath. Does it follow a magnetic strip? a straight track? When you turn it on it goes across the table, but needs some kinda track or something? What?
I'll look for a namebrand later. It sure would be nice to add to a torchmate kinda affair (pattern cutter) to make straight cuts. I got a bunch of floor-plates to cut for posts (shop addition). SO, I gotta get a punch and a pattern cutter going here beforehand. I guess this dealie would cut squares? Right?
I have been in construction since I was 16, just never slowed down enough to watch the other crafts tools at work. There was this fancy robotic welder I got a woodie over once at Sequoah. Around and Around it went. Remote camera like a video game.
