I need to repair my Cuttermaster tool and cutter grinder supports bracket. I have a Lincoln 255 Square Wave and a 230 amp water cooled tig torch. Would I have much of a problem welding 5/8" thick aluminum? The thickest aluminum I've ever welded was 5/16". If the 255 Square Wave and 230 amp torch will do it what procedure should I use? The largest tungsten I have is 1/8" and I assume it won't be big enough so what size should I be using? Thanks in advance.
Ron
Ron
