i have never used it, as it seems not to be available in switzerland.
i understand you coat the parts and can weld them together later? does it work with tig? how heat resistant is it? e.g. if i coat the inside of a 2mm pipe and weld it on the outside to a 4 mm plate (on the end), will it be destroyed?
