Bought an Import 60 Amp Dual Voltage Plasma (w/ Pilot Arc)
  • Bought an Import 60 Amp Dual Voltage Plasma (w/ Pilot Arc)
    On 110V it would cut 1/8 "ok" and 1/4 with some headache. 3/8 I wouldn't even call severing.
    On 220V it cut 1/8 and 1/4 decently, but had to max amps and air pressure to cut 3/8. It would cut it, but it was slow and it blew sparks back towards the start of the cut. Cut towards you, not away. LOL. I was able to make a fair cut with some practice, but it was fairly slow. I won't even try anything thicker. The manual says it will "CUT" 22mm (about 7/8). I doubt it. Out of curiosity I pulled the O/A rig over and made a couple cuts. It was definitely faster and surprisingly cleaner. Atleast for me. On the other hand I made my first O/A cuts 40 years ago, and my first plasma cuts two days ago.
    Cleaner is misleading though. I had barely any slag with the O/A torch, but it was stuck pretty good. I had a lot of slag with the plasma cutter, but it came off fairly easily with my chipping hammer.
    I did find it was much easier to freehand cut straight with the limp lead and light torch of the plasma cutter.
    Honestly, I'll probably use the O/A rig most of the time still. Maybe just use the plasma for things like sheet metal and barrel heads.
    I was using clean dry air. It came through three filter separators and my refrigeration type air dryer. I did read in another group I might get better results with different tips.
    They say 60% duty cycle. Maybe. We were doing testing on 3/8 by 3 mild steel flat bar. We never had any issues that felt like instability from overheating although I am not sure what that would feel like with a plasma torch. We cut all the way across every time. As long as torch distance and speed remained consistent the cut remained consistent.
      not sure if you have one of those cheap plasma cutters like I have, 50 amp rating 110/220 volts. what I did is to get a cheap roller attachment so the tip to keep a constant distance from the work. I had to mod the wheel height and make a special insert for my torch out of delrin and I find that it cuts far better and cleaner and thicker material and the tips last a long time.
      Ed
      Agua Dulce, So.California
      1950 F1 street rod
      1949 F1 stock V8 flathead
      1948 F6 350 chevy/rest stock, no dump bed
      1953 chevy 3100 AD for 85 S10 frame have a 4BT cummins motor, NV4500
      1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
        Mine came with a roller attachment. I may try it again after I fix it, but with the screws snugged down it fell right off.
          Torch consumables are sometimes junk in the cheapos and won't cut worth a sh*t.
            I bought a dual voltage plasma cutter import that had good reviews and does what i need if I am not in a hurry. I run it at 220v with 80 lbs of air.The only issue is heat buildup which i believe contributes to the dross building up on the backside. I have read and viewed videos that recommend a water filled pan with the water at the level of the grating supporting the work to reduce heat buildup. I have some 22 ga sheet metal laying around so i’ll knock out a pan and see how it goes.
