I convinced my boss to let me buy a Harbor Freight Tig/Stick welder and the last two days I have been using it. The best thing you can do for a Harbor Freight welder is to NOT use their welding rods! I bought some 3/32 7018 and 6011 with the welder. I was having a hard time starting the weld and while the welder is 240v input and welds smoothly, although I think the voltage is a bit low. However I got some Lincoln 1/8" 7018 at Home Depot because they didn't have 3/32". Wow, what a difference! At the same current setting the Lincoln 7018 was easy to start, burned smoothly, and was easy to restart.
This job was all out of position welding on the frame of a machine and lots of vertical and overhead welding. I had to be a contortionist to reach many of the welds and some of the fit ups were not very good. So I decided that I would use the Tig instead. I managed to make very nice welds very easily in all positions except a couple where my non-focusing eyes (cataract surgery) made it difficult to see, even though I bought reading type lenses for the helmet and I wear varifocal glasses. The welder came with a foot pedal current control which is nice for bench welding. However it also had a start button on the torch but you can't vary the current. However I learned Tig welding on a machine with no current control, and learned to control the heat by how fast you move and feed the filler so no problem.
