glasses fogging up
  • glasses fogging up
    anybody else holding their breath when welding (tig)? a have a pretty normal helmet and my glasses are fogging up. i can breathe about three times before it gets noticable. lenses are plastic.
    what to do? i was thinking some spray, but i dont want to risk chemicals on the coating. build in ventilator? what else?
    I have the same problem, I purchased some very small 12v fans to try to move air. Have not installed it yet
    Ed
    Agua Dulce, So.California
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame have a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
      How close do you have headband set to hold the helmet away from your face? I've worn glasses most of my life and figured out long ago that I had to position the shield farther away to avoid fogging.
      The extra distance does make it harder to see sometimes, but I've gotten used to it now.
        I had a similar problem with my covid masks
        thr tip I got was to get some medical tape (“paper tape”) and tape the top of my covid mask to the bridge of my nose, upper cheeks, etc. if forces the humid air out by my ears, leaving my glasses clear
        I should think that wearing such a mask under your Welding hood & taping it the same way should work. I plan to try it next time I have to weld (or do anything requiring a face shield
        frank
          Wow! Never heard that problem. What's your humidity there? A 100%?
            Shaving cream.
            put a dime sized blob on and smear it around, buff it out.
              humidity is low, usually 30% outside and less than 55% in the shop. rubbing, buffing is difficult, as with plastic and the coating(s) i would have to clean the lenses meticulously every time. please report how it went with the ventilator. will you be pulling air out?
                Rain-x makes a product for preventing fog on the windshield. there are also sprays specifically for anti-fog on eyeglasses
                Buy Rain-X AF21106D Interior Anti-Fog Glass Cleaner with an everyday low price and fast shipping! JB Tools
