Braze copper pipe with brass rod?
  • #16
    Originally posted by johansen View Post
    I flow propane through systems when brazing, works just as well as argon or nitrogen. No need to lug a tank around.
    As for using 5 to 15% silphos for copper to brass.. It sort of works. Its not reliable. Still get a brittle joint.
    You dont need oxy acyetalene, i have brazed 3/4" pipe with two propane torches and ceramic fiber insulation. 1/2 pipe can be done with 1 torch..
    Flowing propane through pipes while getting them red hot brazing with a open flame, what could possibly go wrong ??
    • #17
      Once the propane makes it through the system you just light it on fire wherever it comes out. You dont need more than a standard torch worth of propane so it is not a fire hazard. You can turn the source down to the point its just like that of a cig lighter if you want.
      • #18
        If it works for you - keep doing it. I use oyy acetylene torch so I can get on it and off of it quickly. Usually I can complete the braze before there is much oxidation of the bare copper.
        I use 0% siphos becasue it is cheaper and more readily available.You use what works for you.
        I flow nitrogen at about 3 psi and a very low flow rate. I don't want the N2 to blow the silphos out of the joint when I am trying to seal it.
        Brittleness? I have had no known problem with a brittle joint. I'm not sure how I would know if the joint was brittle. There is roughly double the copper at the joint in addition to the silphos braze. I have have never seen a brittle mechanical failure at or near the joint. But then the HVAC joint really don't have a mechanical load on them. The only real load would be hoop stress from the pressure of the refrigerant.
        • #19
          5% Sil Phos is what I used all the time in my 30 years plus. I have used the Harris flux when brazing old copper or copper to brass. Yes you can Sil Phos with propane or Mapp gas depending on the size of the pipe. I usually used a B tank of acetylene with a Turbo torch cheaper and more portable.
          Retired - Journeyman Refrigeration Pipefitter - Master Electrician - Fine Line Automation CNC 4x4 Router
          • #20
            Originally posted by gzig5 View Post
            Thanks! I've got fresh oxy-acetylene tanks.
            Would TIG work with these rods as well? I saw a utube where he did it with silicon-bronze rod and one that used copper ground wire from some Romex.
            Given the choice, I'd use gas with the proper solder instead of silly rod on TIG. I tend to make cold welds or blow through low melt temp material much more readily with TIG brazing.
            -paul
