Have any of you guys used it? I just heard of it for the first time a little while ago.
Paint on flux for the inside of stainless tube...
*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.Tags: None
Never heard of it. What's it for? Welding on the tube? I guess it would be better than nothing but
the correct way to weld on SS tube is to purge the inside with argon while the welding is taking place.
The flux might help but it's going to need a long brush to spread it on the inside if you're welding two
long pieces of tube together...Keith
__________________________
- Likes 1
Originally posted by LKeithR View PostNever heard of it. What's it for? Welding on the tube? I guess it would be better than nothing but
Anybody ever heard of the stuff and/or used it?
Originally posted by oxford View PostI’d probably just use it, or back purge, or use nothing. There really isn’t any absolutes with this stuff.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
I had sort of heard mention of this stuff but never pursued it as I don't have a much need for something like this. But it is interesting. Looking at some of the comments on Amazon someone mentioned that there is info about it on youtube. And so there is. Search Solar type B flux on youtube and you'll find some reviews and such. Interesting stuff.
Solar Welding Flux
Description: Welding Flux
Solar Flux is a complex chemical compound in the form of a very fine powder. Solar Flux is mixed with alcohol (methanol/methyl alcohol preferred) and brushed on the weld joint. It is formulated to shield the back of the weld joint from oxygen, dissipate heat and unwanted oxides, and to clean the surface of the metal. It will aid in the flow of filler metal over base metal and form a protective barrier to prevent re-oxidation and heat scale.
Type B for stainless steel, (except 309, 310), precipitation hardening steels, chrome-moly steels, other alloy steels with nickel content below 25%.
From Harris website.
Have used it as a 30+ year pipe welder, but only in specific conditions. Always prefer argon purge. However, it does what it is designed to do. Great for small welds as the flux dries and can flake if applied to larges areas a dries prematurely.
https://youtu.be/__n5TA2CP3g
Mr. TigLast edited by David T; 02-09-2022, 12:13 PM.
Ive used lots of it. It works reasonably well for single pass welds on SS. It flakes off as you weld so you shouldnt do multi pass welds with it unless you can somehow get in to recoat it for the next pass. And...you really should remove the flux after you weld as it is very corrosive. So ya...back purging with argon is way easierI have tools I don't even know I own...
- Likes 1
