Originally posted by psomero
View Post
Plasma Cutter, Expensive vs El Cheapo
Central Ohio, USA
Originally posted by alanganes View Post
What function does the z-axis serve on a cnc plasma machine? Is it adjusted dynamically as the cut is made or it is simply to dial in the best height for a particular material or whatever? If it is adjusted dynamically, what is used to determine the optimum height?Mike
Central Ohio, USA
Mine is red, but this seems to be the current model: https://www.amazon.com/Lotos-LTP5000.../dp/B0052OX876
If you think you are ever going to upgrade to even a low end CNC plasma table, I recommend that you get a plasma cutter that can be fitted with a vertical machine torch. I have used various Hypertherm models for 25 years, almost exclusively on CNC machines. Right now I have a Hypertherm 45X with a machine torch, and it is great. You don't want to get half way through cutting a shape out of a $50 steel plate and have it fizzle out, ruining the plate.
$2,500 for a plasma cutter is a lot of money, as is the price of a low end CNC set-up. The average hobbyist has a hard time justifying it. That said, many of the same folks think nothing of spending that kind of money or more for a snowmobile, jet ski, or motorcycle for recreational use. The kind of work possible with a CNC plasma cutter can't be performed with any other type of equipment other than another more expensive CNC machine.
A few examples done with my 2' x 2' home-made CNC plasma table and Hypertherm:
Originally posted by Tmate View PostIf you think you are ever going to upgrade to even a low end CNC plasma table, I recommend that you get a plasma cutter that can be fitted with a vertical machine torch. I have used various Hypertherm models for 25 years, almost exclusively on CNC machines. Right now I have a Hypertherm 45X with a machine torch, and it is great. You don't want to get half way through cutting a shape out of a $50 steel plate and have it fizzle out, ruining the plate.
Central Ohio, USA
I have an El Cheapo, and while I can make "cleaner" cuts with it in some materials I am much much faster with a torch. I rarely use either for breaking down stock. I use the horizontal bandsaw unless I need to cut complex shapes. Then I only breaking out the torch or plasm if I can't do it on the mill.
When I first got the plasma my son and I took turns with both the torch and the plasma on upto 3/8 hot rolled flat bar. On average we got less slag with the torch, but the slag from the plasma knocked off easier and cleaner with a chipping hammer. Its a wash for me. The plasma might have won out on 3/16 and thinner, but the torch eats the plasma for lunch on 1/4 and thicker. The plasma is nice in that I can use it to free hand aluminum sheet. Something not practical (not possible?) with the torch. Of course I can cut thicker and thicker with the torch just by changing the tip.
On steel I have a lot of ways to cut it. I'm more likely to use the circular saw (metal cutting) or a zip disc than the torch or plasma cutter, but sometimes they are the best tool for the job. For the most part I consider them in the better to have it and not need it category then need it and not have it.Last edited by Bob La Londe; 01-26-2022, 05:04 PM.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
Below is an example of the kind of cuts you can get with a Hypertherm Powermax. This is 1/4" plate and the settings were 65 amps @ 88 inches per minute on the CNC table. Pictures are top, side and bottom. Notice the lack of dross other than pierce points, this part was not cleaned up nor did I tune the cut settings. This was the first time I cut 1/4 plate and those are Hypertherm book values.
Central Ohio, USA
I have used a hand held plasma cutter, I have never worked with one on a cnc table. A plasma cutter is on my wish list though. It is far more of a "want" than a "need" so there is not a lot of priority at the moment. I am still waffling on what I want to get.
- 1 like
Originally posted by Ohio Mike View Post
My plasma CNC is actually a Langmuir Crossfire Pro. Its an awesome table at its price point. Despite is "pro" moniker is not a table I'd want to run in business where employees are using it. I make sure the wipe the rails down each time its run and I'm careful not to crash it (the Pro doesn't have limit switches). If I had to spend more than $3000 on the table I wouldn't have purchased one. There at lots of other nice tables out there but anything better than it is twice the money.
I have enough experience with CNC stuff and I notice the naggy little things that can lead to failures that the other guys are too green to pick up on quite yet, unless the thing scraps a part.
Since I posted this, our torch height signal blew out on our Everlast and we bought the 80A unit to replace it. Guess we have a spare hand-torch-only machine now.-paul
Originally posted by Ironbearmarine View Post
The z axis control insures that the tip is at optimal distance from the material. This is done by maintain a constant voltage. A longer or shorter arc is detected by the increase or decrease of the voltage and the controller will adjust the z until the proper voltage of the arc is achieved. This means cleaner cuts, but more importantly is not having to level your target material, you get automatic height adjustment for warped or untrue plate, or sheet metal that warps during the cutting. Also you can pre program clearance jumps for multiple objects that may tip up, causing collisions with the head. Also i have noticed that i get better mileage out of my consumablesLast edited by alanganes; 01-30-2022, 06:15 PM.
