What is the criteria for changing the MIG gun nozzle and contact tip? What are the signs that the nozzle or the contact tip or both need to be replaced? I have a Century 130 115v, 20A welder. I've had it about 25 yrs. I bought a small package of consumables back then and still have most of them. I should note that I don't MIG much - maybe (5) 10 or 11 lb rolls of wire plus a few small rolls.
Recently I was building up a surface with MIG, had the "heat" rheostat at 100% and the feed rate at about 45%. 0.030 ER70S-6 wire. I was getting too much popping, sometimes in quick succession (when popping there is no welding for an instant) and sometimes I could feel the wire pushing the gun away from the weld. What causes the popping and how to reduce/eliminate? I lightly adjusted first the power and then the wire feed with no major improvement. I replace the contact tip (probably first time in several years) still no improvement. I just put up with the popping. Near the end of the welding project I aggressively began to adjust the feed rate and found that a feed rate of about 20% reduced the popping greatly. BTW, this was US Forge brand (China) wire purchased from Menards - not sure what effect the wire might have.
How does one determine the correct gas flow? I know from personal experience if one does not turn on the gas, the weld looks like a miniature sponge. Beyound that extreem, how does one know the correct gas flow has been dialed in? I use a 40 cu ft cylinder of MIGmix. Sometimes it lasts me several years. Last week it lasted 6 days and I used a little less than 10 lbs of .030 wire. 40 cu ft of MIGmix cost me $44 with tax/fees - I am trying not to waste it.
