I bought a bottle of Co2 on monday for my mig welder, have wasted a lot of mix gas on autobody repair and the weld gets ground down anyway. And I then saw that Fitzee (youtube) uses co2 for his impressive work so why should I pay twice as much for mix gas refills. I decided to try it out.
After welding with it for an evening on my car I have so far found I needed to set the voltage two steps higher on my machine and also up the wire feed. But at the same time it seems less prone to blowing holes than when I was using mix gas. Which I found really strange. It does spatter more and feels a little "rougher". But for half the price of mix gas I think it's entirely viable as long as short circuit or globular is enough.
To me this goes to show you can't just trust what you read on message boards. Gotta try things out yourself. Based on what I've read there I would've thought Co2 was barely workable alternative to mix gas.
