I just picked up a HF plastic welder. The kind with the air blower built in. http://www.harborfreight.com/plastic...ent-96712.html
I opened up the instructions and learned not to burn my hands and not to weld in the rain, etc. But there was not much on technique on how to actually weld plastic.
I had a leaking PE gas tank and found some like material and by trial an error was able to seal the leak. I then tried it again on another tank and that was a disaster. The material was not the same and it was not as thick and I quickly burned through the material.
So, how does one weld plastic? They supplied 3 tips but failed to explain when they should be used. What type of motion should one use to heat the material and add filler plastic. Do you deal with a traditional puddle? How do you do it????
Randy
Randy
