Hi Group,
I've had a miller 135 MIG 120v machine for a few years and it has served me well. Auto sheet metal repair and smaller steel projects. Home hobbiest type of welding.
This weekend I purchased a Miller 185 older style machine "1997 yr mfg", for a good deal, $400.00. It came with a AL spool gun, 2 bottles, very low hrs.
The question is, in testing the 185 MIG on steel 16ga sheet metal I have the volts to the lowest setting "10" and I'm still getting burn through, not consistently but once in a while. I have adjusted the wire speed from a high of 30 to a low of 10 and changed my travel speed to correspond. Still the same results. With the 135 MIG I can do the same 16ga metal without the burn through. With the 185 MIG voltage at the lowest setting can I do anything to compensate for the extra heat? Gas is 25/75 and flow is set at 20 cfh.
I think I may need to keep the 135 for light things, which I was hoping to sell to keep my slush fund in the black.
Any and all comments appreciated.
TX
Mr fixit for the family
Chris
TX
Chris
