To milmat1: Soon as I read you entry I ran down stairs to check mine. I have a 1220 also but not the XL [low buget- midas].
I didn't take the time to put a dial on the mill but as I could tell I have very little if any movement. Plus there has never been a time that it has jumped out of gear.
VISES' I stll use the angle vise that came with mine. But I did make 1/2 plate 5Wx8L to mount the vise centered over the mill table. This make it much nicer when you try and center something under the milling tool. Took the time to mill a couple of centering lugs on the bottom of the plate so it goes in the same location when ever I return the vise to the table its very close zero x-y each time. Saves me a lot of time and head ach.
Heres one for ya!! I'd like to mount a 4" dial caliper to the face of the mill head to get a more accurate down feed reading. A fella did this to a Jet mill/drill in Feb/March issue of Mach. Workshop. But his machine has much more room to mount the Caliper to than does the Smithy. any ideas??
Thanks Jim.
Thanks Jim.
