Dumore cutter grinder
  • Dumore cutter grinder
    Does anyone have or know anyone who has a Dumore Centra Point Cutter Grinder model 8342? i've acquired one of these machines and it does a very nice job of sharpening the end teeth on end mills. I'm unable, however, to grind helical or straight flutes on reamers or end mills because I don't have the tooth rests. From the pictures in the users manual they look like they should be easy enough to make if one had a drawing or tracing with dimensions. I've tried Dumore Corp. but they no longer have any information on this grinder and no luck on the internet either. If anyone has any information I would greatly appreciate it.Thanks
